Author Topic: Transfer 10mA square wave through glass  (Read 800 times)
Offline Houseman
« on: May 07, 2021, 06:22:37 am »
Hi forum.
Sounds strange but I need to transfer a 10mA square wave (period 3ms duty cycle 20%) (-15V +15V) signal through a dividing glass I cannot drill with wires.
I have a generator that outputs with two wires: signal wire + ground (return) wire to the transducer but the problem is that the transducer needs to be inside a glass and completely sealed. No leakage is allowed so no wires has to cross the sealing.
First question is: is such a device possible?
I was thinking of an inductive transfer but the problem is if I can transmit square waves.
Do I need to code them?
Could you please point me to some direction?
Thank You so much
Steve
« Last Edit: May 07, 2021, 06:27:31 am by Houseman »
Offline Robert Smith Eco Warrior
Re: Transfer 10mA square wave through glass
« Reply #1 on: May 07, 2021, 06:48:40 am »
Glass is a good insulator so I don't know how you would directly conduct a signal. Could you have an infrared led one side and reciever the other side to pass the signal through the glass?
The following users thanked this post: Houseman
Offline TopGun
« Reply #2 on: May 07, 2021, 06:57:42 am »
Maybe some kind of optical isolating transfer? You can square it up with an opamp later...
Offline Twoflower
« Reply #3 on: May 07, 2021, 07:31:21 am »
The question I have is: Do you want to transfer the information, the energy or both?
If it‘s just the information you could amplify a weak signal after detecting it at the receiving end of the fiber. Think of it like a really long opto insulator.
Transfer energy is much harder to archeive. But there are solutions to get energy to the receiving end (reasonably powerful laser and photovoltaic cells at the receiving end). But that has losses. If you can‘t amplify the signal you can‘t use that.
Online nfmax
« Reply #4 on: May 07, 2021, 07:41:45 am »
I don't know the details of your glasswork, but hermetic glass-to-metal seals are a well known technology (think thermionic valves). You may be able to use one with a low temperature glass frit seal to your glasswork?
Offline Houseman
« Reply #5 on: May 07, 2021, 07:42:38 am »
Thank You all.
In reality I need to transfer both (energy + information).
The glass is not such thick (think about a lab becher). The fact is that the glass can be further replaced with non light-transparent material.
So as far as I understand, it is better to transfer energy and then let al the circuitry inside right?
Regards
Offline Brumby
« Reply #6 on: May 07, 2021, 10:41:07 am »
It would be a whole lot easier to offer useful suggestions if you can be more specific about what you are actually trying to do, rather than get us to blindly present ideas to a narrow view of the problem.
When the full scenario is outlined, other options become apparent - and better solutions can often be found.
The following users thanked this post: janoc, wraper, Doctorandus_P
Offline MasterTech
« Reply #7 on: May 07, 2021, 11:02:17 am »
Your problem needs to be split in two:
1) Powering the circuit inside the glass/plastic or whatever non-conductive material you need. For this you need a transformer primary outside and a secondary inside
2) Transmitting the signal, via optical means in case of translucent material or transformer for opaque materials.
Offline Zero999
  • 0999
« Reply #8 on: May 07, 2021, 12:43:12 pm »
Again this sounds like an X Y problem. Can we please see the bigger picture?
The power is 150mW, so a transformer is the only sane way to do this. It can be used to transmit both power and data. Don't transmit the actual signal. Use a much higher frequency and signal between high and low levels,  by changing the frequency slightly; a technique known as frequency shift keying.
« Reply #9 on: May 07, 2021, 01:00:30 pm »
good idea about the split transformer.  :-+
Online David Hess
  • DavidH
« Reply #10 on: May 07, 2021, 10:39:55 pm »
With some cleverness, the same split transformer can be used for power and information transfer.
Offline wizard69
« Reply #11 on: May 07, 2021, 10:58:41 pm »
I'd look into this, that is glass to metal sealing, as the best way forward.   Old tubes easily accommodated 8 pins and many more for certain types of tubes.   You apparently have electronics inside the glass already so adding wires shouldn't be a problem.
Of course doing this isn't easy if you are not familiar with glass work.   You may be able to get help from a local glass blower or even somebody working with neon lights.    Glass blowers often have been called upon for custom laboratory glass, so it might help to check with a local university or research center.
Of course going this route pretty much makes for a permanent container so that might be an issue.   There are other ways to go if you have a two part container, that is a container with a plug or lid.
Offline Marco
« Reply #12 on: May 08, 2021, 12:09:48 am »
Since this is in the beginners forum ... solve the power transfer with modules : https://www.adafruit.com/category/331
What's left is sending a square wave with a LED and receiving it with a phototransistor and creating the the 30v peak to peak signal inside the glass.
Offline MIS42N
« Reply #13 on: May 08, 2021, 09:34:31 am »
A quick read says common inductive power transfer works above 100kHz. Could you modulate that to transfer your information? Swap between two frequencies and detect that to recreate the square wave. It would not be instantaneous, the receiver would have a delay. Alternately inject a small amount of RF (garage door opener frequency) for on, pick that up in a suitable receiver.
Offline radiolistener
  • Country: ua
« Reply #14 on: May 08, 2021, 04:50:30 pm »
It looks like RFID technology, so you can use it.
Online geggi1
« Reply #15 on: May 08, 2021, 05:34:00 pm »
You should loock in to inductive transfer.
Possible if you need to power a circuit and  use inductive power transfer almost like a inductive charger for a mobile phone. The signal in return could be som kind of optical transfer possible your signal modulated on top of a led source with a photo diode as detector.
