Hello!
I'm designing and simulating a current integrator, and I have to know it's transfer function H(f) = Vout/Iin because I plan to reset it by placing it inside a control loop that when activated will dispense current until it's output reaches zero.
I've been having some difficulties understanding the results obtained and would greatly appreciate some help. First of all using the test circuit of the first image I get the results shown in the second picture.
Now, mathematically, I understand that for an ideal integrator the gain at f=1Hz is 1/2*pi*C, which seems to agree with the results, but the open loop gain of the used AD712 at this frequency is just 115dB (verified with another Spice simulation so it is correctly modelled). How can the gain of the integrator be greater than the open loop gain of the op amp?
Furthermore, how can it be that the gain of the integrator reaches 0dB at 10GHz (can you believe it!)? I'm assuming I screwed up something in the simulation, but I've not been able to find what.
Any help is greatly appreciated!
PS1: In order to obtain this result I've had to specify that in the initial condition of the capacitor it's charge is zero. If not the simulator gives a completely different result.
PS2: In a transient simulator I verified the circuit works properly in the time domain (which it does) and as expected with currents high enough the output doesn't slew fast enough.
Hello,
It looks like your transfer function for AC is:
Vout=(5.0e10)/(pi*f)
but that is in pure theory, where there are no limitations on voltage or current and no limitations on what the components can do. That would, for one example, mean the op amp can take an infinite input voltage without blowing out and can source an infinitely high output voltage.
We all know this cant work in the real world and looking at the output for even 100Hz we can see the output is way above anything even remotely reasonable.
To add to that, during the first instant the output can not respond at all. That puts 1 amp through a 10pf capacitor for the first instant of a cosine wave input, and the voltage due to that appears at the inverting terminal of the op amp. Note that this is a current drive not a voltage drive, so there is no delay. Because it is an electrical current drive it MUST be inside a closed loop (barring any non conservative losses) and that means it must immediately pass through the capacitor. If you look at what voltage this would produce at the inverting input you will find it will be very very high. In fact, it will reach up to 1/C volts for the very first instant in theory, which is way too high for any op amp i know of.
So maybe you need to rethink this project test setup and see what you can change to make it a more reasonable circuit and/or a more reasonable test setup.
