Author Topic: transformer  (Read 11443 times)
Offline christos
  • Country: gr
transformer
« on: January 11, 2014, 06:04:03 pm »
i have a transformer that get output 52 volts
its 10x10cm  very heavy
how do i know how many amps it can get at the output?
its    26-0-26
if you need pic i can show you
Offline Rudane
    • Electrical Engineering 101
Re: transformer
« Reply #1 on: January 11, 2014, 06:22:05 pm »
Do you have any identifying numbers from the device? I'm not sure you can determine the maximum current out without knowing more information about the transformer.
Voltage appears across and current flows through.
Offline christos
  • Country: gr
Re: transformer
« Reply #2 on: January 11, 2014, 06:40:31 pm »
nothing..it got 2 secondaries 26v each
Offline Simon123
  • Country: si
    • Youtube channel
Re: transformer
« Reply #3 on: January 11, 2014, 06:42:47 pm »
Do you know, what it was connected to before?
Offline IonizedGears
Re: transformer
« Reply #4 on: January 11, 2014, 06:45:37 pm »
Assuming that your input is 120v, the ratio is 52/120(.4333) for the two combined secondaries  for V, or 120/52(2.3) for I. We could calculate this if you had the impedance of the main coil or the current through the main coil.
I am an EE student with interests in Embedded, RF, Control Systems, and Nanotech.
Offline christos
  • Country: gr
Re: transformer
« Reply #5 on: January 11, 2014, 06:46:40 pm »
a 40watt mic amplifier ..it used one more transformer at the output for the speakers
Offline christos
  • Country: gr
Re: transformer
« Reply #6 on: January 11, 2014, 06:48:55 pm »
input is 230v
Offline IanB
Re: transformer
« Reply #7 on: January 11, 2014, 06:51:03 pm »
its    26-0-26
The rating of a transformer is measured in VA (more or less the power handling).
Two ways to estimate the VA of a mains transformer are from the overall weight, or the dimensions of the core (height x width x thickness).
Given either or both of those, there are rules of thumb that will give you a ball park estimate.
Offline christos
  • Country: gr
Re: transformer
« Reply #8 on: January 11, 2014, 06:52:35 pm »
if i conect a  10ohm 10w res and measure the current..at the same time measure the tempp from the xformer ,,should it work?
Re: transformer
« Reply #9 on: January 11, 2014, 06:54:12 pm »
Well then, 52/230(.23)  for V, 230/52(4.2) for I. If you have the input impedance, then we could give you an exact answer. One way to do it is keep loading the secondaries until the voltage starts to drop and you could use E/R to find the max amperage for the secondaries this way.
Offline IanB
Re: transformer
« Reply #10 on: January 11, 2014, 06:55:28 pm »
Item: the transformer provides 50 V
Item: the current through a 10 ohm resistor will therefore be 5 A
Item: the power dissipated in the resistor will therefore be 250 W
Conclusion: smoke will occur, if not flames
Offline IanB
Re: transformer
« Reply #11 on: January 11, 2014, 06:57:35 pm »
As noted above the 10 ohm resistor is not a suitable load. But in general, increasing the load on a transformer until it starts to get warm is a good way to find the upper limit on the power handling.
Offline christos
  • Country: gr
Re: transformer
« Reply #12 on: January 11, 2014, 07:00:02 pm »
its    26-0-26
the core is 4x4x4
Offline rdl
Re: transformer
« Reply #13 on: January 11, 2014, 07:00:19 pm »
This might be a clue... or am I wrong?
Offline christos
  • Country: gr
Re: transformer
« Reply #14 on: January 11, 2014, 07:03:28 pm »
so it may work?
Offline kg4arn
Re: transformer
« Reply #15 on: January 11, 2014, 07:04:28 pm »
If this helps get you in the ball park
About 70VA/kg is what I have read.
I have 2 transformers here that I have weighed:
Hammond mfg rated at 30VA weight = 0.522kg --> 58VA/kg
Signal mfg rated at 100 VA weight = 1.22kg --> 82VA/kg
Offline christos
  • Country: gr
Re: transformer
« Reply #16 on: January 11, 2014, 07:07:01 pm »
ill post some pics
Offline christos
  • Country: gr
Re: transformer
« Reply #17 on: January 11, 2014, 07:32:02 pm »
well the core is 7 height 5 width 7 length
its 2.5 kg te metal is 9 height 11 width and 3 leght
Offline IanB
Re: transformer
« Reply #18 on: January 11, 2014, 07:37:19 pm »
the core is 4x4x4
In what units? mm? cm? inches?
When you give measurements you must always give the units of measure.
Offline christos
  • Country: gr
Re: transformer
« Reply #19 on: January 11, 2014, 07:43:19 pm »
the core is 4x4x4
oups..read the new measurements if you didnt and its in cm
Offline IanB
Re: transformer
« Reply #20 on: January 11, 2014, 07:55:02 pm »
I cannot make sense of your measurements. The core is the metal part with the laminations that has the coils wound around the middle of it. The height and width will usually be as big as the transformer. The thickness will usually be less than the height and width.
Offline christos
  • Country: gr
Re: transformer
« Reply #21 on: January 11, 2014, 07:57:19 pm »
oups at the core i mean the windings..ill post a pic
Offline tasos987
  • Country: gr
Re: transformer
« Reply #22 on: January 11, 2014, 07:57:25 pm »
IMHO reply #9 helps always to stay on the safe side....
Other bulk solutions i think include a minimal risk of smoke poduction
"All I know is that I know nothing" Socrates 470-399 B.C.
Offline christos
  • Country: gr
Re: transformer
« Reply #23 on: January 11, 2014, 08:01:06 pm »
http://postimg.org/image/cfu7djqjf/
Offline christos
  • Country: gr
Re: transformer
« Reply #24 on: January 11, 2014, 08:01:53 pm »
taso ellada edw
