Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Is it OK to put 0603 resistor on the 0402 pads?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is it OK to put 0603 resistor on the 0402 pads? (Read 5486 times)
Iron Downey
Contributor
Country:
You have to do the best with what God gave you
on:
May 16, 2016, 09:57:45 am »
I made a mistake for the package of the resistor. The pads on the board is 0402, I bought 0603 and I have assembled 1 piece now. See the attached picture. It looks fine, but I'm a little wonder if it would have some bad effects?
Logged
PCB and PCBA engineer on
http://en.zfpcba.com/
, a professional PCB and assembly manufacturer
nour
Frequent Contributor
Country:
calm down, it is just a smoked oPamP!
Re: Is it OK to put 0603 resistor on the 0402 pads?
Reply #1 on:
May 16, 2016, 10:22:23 am »
That looks perfectly fine to me
Logged
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
Psi
Super Contributor
Country:
Reply #2 on:
May 16, 2016, 10:28:41 am »
It will work fine for one-off stuff
Logged
m98
Country:
Reply #3 on:
May 16, 2016, 12:25:34 pm »
Wouldn't expect any problems.
Logged
Neilm
Super Contributor
Country:
Reply #4 on:
May 16, 2016, 06:49:28 pm »
About the only problem I can think of is that it will work fine - but if you build one with the smaller resistor you find that one of the parts is out of specification - most likely dissipating too much heat. What you have here will be OK, but when you make one with the small component remember to check none of them are getting too hot.
Logged
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code
https://ts.la/neil53539
Iron Downey
Iron Downey
Contributor
Country:
Reply #5 on:
May 17, 2016, 07:52:15 am »
The boards work fine, just not in good look. I have accpeted it O0
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
