If you went Analog new you'd be probably paying close to the same price as new Digital but not getting as much for your money. You mention about future proofing so in that case it may be better go digital but that is your decision.
I'll gladly give you the details of one of the application engineer at Rigol if you'd like to speak to them about your questions.
Hope you have a lovely day!
Joy
You would be crazy to buy a new
analog,as they are not anywhere near the performance level of 30 year old Tektronix instruments of that type.
If you are only interested in audio spectrum analysis,you can probably get by with a "top of the line" soundcard in your PC.
PS---.I should have put the emphasis on
"new" rather than "analog" as if you read it quickly,it makes me look like a "fan boi" for DSOs,which I most certainly am not.
I meant that any analog 'scopes you might buy
new will be quite basic,as they are built down to a price---old Tek & HP instruments were intended for professional use,& generally had every feature possible with an analog instrument.
