The ARRL Radio Amateur's Handbook is a time honored, traditional source. Having said that, I have found recent editions lacking in coherence and accuracy. If you can find an old one, say before the 1960s, I would recommend it. Of course much has elapsed since then so you don't get up to date info, but they haven't repealed Ohm's law as far as I know.
The newer ones seem more to be trying to fulfill an obligation to publish yearly rather than an attempt to provide a solid source of technical information. I will say the same for the Antenna Handbook. ARRL isn't what it once was, and to quote Will Rogers, it probably never was.
