Author Topic: Transistor Identification Help  (Read 1579 times)
Offline Robbie010Topic starter
« on: February 02, 2019, 11:33:15 pm »
Hi all,
I'm currently trying to identify the components on an old amplifier circuit so that I can try and draw up a schematic, but I'm struggling to indentify some transistors.
The markings on them read as follows:
MHPS L01
MHPS L51
BF2 45A M131
F420 PH5N
They all look pretty much the same as per the attached picture but can anyone tell me the correct values for these transistors??
Thanks in advance.
Offline helius
Re: Transistor Identification Help
« Reply #1 on: February 02, 2019, 11:40:48 pm »
MPSL01
MPSL51
BF245A
BF420
Offline Mortymore
  • Country: pt
« Reply #2 on: February 02, 2019, 11:41:33 pm »
See if this make sense on your circuit:
MPSL01 NPN
MPSL51 PNP
BF245A JFET-N
BF420 NPN high-voltage
« Reply #3 on: February 03, 2019, 12:02:15 am »
Thats excellent, thank you very much!! :-+
I am yet to fully test the components but, assuming the transistors are all functioning properly would there be any benefit to swap these out for a modern replacement whilst I've got the amp stripped down?
I note that some of the transistors are now obsolete so would there be a benefit to swapping the out for modern replacements?
Thanks again.
Offline Mortymore
  • Country: pt
« Reply #4 on: February 03, 2019, 01:13:04 pm »
You actually may be forced to move to compatible replacements if you can't find the original references.
My advise is, since it's an audio amplifier, the transistor replaced in the right/left channel  should be replaced on the other channel also. It would be even better, even if it's just one transistor needed to be replaced, that you buy not only one for each channel, but a few more and try to match a pair of them with the same gain (hfe), so you wont end up with unbalanced right/left channels.
Try to put the amplifier working, first of all. Next you can play (an educated play) with different components to achieve better results.
Good luck.
Re: Component Identification Help
« Reply #5 on: February 05, 2019, 06:30:44 pm »
Thanks everyone, those detais were very useful!
I am still struggling with this component, I am going to pull it tomorrow and test it but I had a poke around with a multifunction tester today (in-circuit) and got a better look at the markings.
It has a feignt red band at one end (like a diode) and is marked HSG 39F.
When testing it as a zener diode it came back with a Zener voltage of between 16 - 21v, however, when testing it as a normal diode its forward voltage was 3.9v with a capacitance of and 68pF
Any thoughts?
Offline Benta
« Reply #6 on: February 05, 2019, 06:43:40 pm »
Any thoughts?
This has already been answered in a different thread. 39 pF polystyrene.
The following users thanked this post: Robbie010
