Author Topic: Solder Wire Flux Content  (Read 3147 times)
Offline jnv108@gmail.comTopic starter
« on: September 01, 2014, 04:41:01 am »
I need to buy solder wire and this is very confusing. I would like to buy 0.5mm solder wire, but how much flux needs to be inside the wire?
1% 2% 3%
- Is 1.2% flux on the solder wire good enough for a beginner?
[NB: I am planning to just play around with circuits, and teach myself some basic electronics. ]
I am new to electronics and soldering ETC. I have just bought myself a Dick Smith Soldering iron
http://www.dicksmith.com.au/tools-hobbyist/temperature-controlled-soldering-station-dsau-t2200
Offline Fsck
  • sleep deprived
Re: Solder Wire Flux Content
« Reply #1 on: September 01, 2014, 04:51:35 am »
most people will add flux any time they solder (either pen or bottle with a fine tip, etc) so it doesn't really matter in general.
"This is a one line proof...if we start sufficiently far to the left."
« Reply #2 on: September 01, 2014, 05:27:55 am »
Hi
Thanks for the reply.
I will be getting a flux pen anyway. But what % would you suggest included in the solder wire itself?
Offline Fsck
  • sleep deprived
« Reply #3 on: September 01, 2014, 06:04:45 am »
I use kester 44, which typically comes with 3.3% flux by weight.
Offline DanielS
« Reply #4 on: September 01, 2014, 06:15:43 am »
The more flux you have in the solder itself, the less likely you are to need to add any in a typical soldering job. If you are going to solder on bare copper a lot, such as tinning copper wires, use the highest-flux solder you can find so extra solder will add extra flux to help solder wick all the way through. If you are going to be soldering mostly on tinned copper or will be applying your own flux either way, you can skip flux in the solder wire altogether.
I have 3% rosin solder wire and practically never need flux for soldering unless the surface I am trying to solder to is in pretty bad shape - usually need to give it a good scraping first in those cases.
Offline G7PSK
  • It is hot until proved not.
« Reply #5 on: September 01, 2014, 05:30:19 pm »
You cant go wrong with "more flux the better" in the solder. Also particularly at first very fine solder is hard to manipulate and feed into the joint learn to solder using .9 solder go to .5mm as your skill improves.
Offline David Hess
  • DavidH
« Reply #6 on: September 01, 2014, 07:03:11 pm »
The only time I would use solder with a smaller sized flux core would be in a production environment where the surfaces of the boards and parts are of a known quality.  In any other application, I would use the largest flux size available.
My favorite is Kester 44 with core size 66 which is 3.3% by weight.
