How can I determine the ac center-tapped voltages from the transformer secondaries that will produce the dc voltages shown in this schematic?
I do not see any ratings for the output voltages of the transformer. We have to know that too.
We also have to know the current rating or VA rating of the transformer.
The peak output with a capacitor filter is usually 1.4142*Vac, so a 10vac winding produces about 14.1v DC peak. With two diodes in series, it can fall to 12v or even a little lower with load because a load causes higher peak voltages across each diode.
Sometimes the ripple is estimated also, as:
dV=I/(f*C)
where
dV is the change in voltage (ripple),
I is the load current,
f is the frequency (twice the line frequency),
C is the capacitance in Farads.
This can help calculate the lowest voltage output.
Another thing to consider is the "low line" voltage. This is typically 10 percent lower than nominal, so a 120vac line can go down to 108vac. It some locations it can go down even more. I think it is the same in the UK but you have to check the nominal voltage for any place first.
