I'm looking at a second hand transformer, specs below. My question is these are listed at automation use, the thermal fuse wires and thermistor wires, would they connect to the powered equipment. In it original use that is ? If repurposed where would the thermistor and thermal fuse wires connect to ? Any help appreciated thanks for reading.
Connection details
Blue - 0v AC Primary
Brown - 230v AC primary
Black - Thermistor
Black - Thermistor
White - Thermal cut off
White- Thermal cut off
Orange - 0v secondary O/P
Yellow- 27.5v secondary O/P
Primary Input voltage
0 - 230 Volts ± 10% 50 Hz
