Author Topic: Switching Question  (Read 313 times)
Offline Lewham5115Topic starter
Switching Question
« on: May 24, 2024, 04:53:26 pm »
I've got a project where I want to be able to switch 3-5 potentiometers between two different banks of them. So an A bank of between 3-5 pots, then a B bank of 3-5 pots.
Could someone point me in the direction of how I should look to implement this?
The signal going through these pots are all very low voltage. And I need to be able to switch between these two different banks with just a single switch.
Is there some sort of chipset that will allow me to accomplish this? Should I look at using relays?
Any help would be appreciated.
Online themadhippy
Re: Switching Question
« Reply #1 on: May 24, 2024, 05:59:57 pm »
How are the pots wired? worst case your after  15 pole 2 way switching,if however the pots are commend at one end or both youll only need  10 or 5 pole 2 way switching.
