I just want to inform everyone about the developments. The problems with the multimeter became more and more pronounced, so I finally took it apart, cleaned the contacts and applied Kontakt 61. Now it works perfectly again, 0.2Ω short contact every time without any problem. The only question is - how long.
Now I want to buy another budget multimeter as a gift. Do you still recommend me to buy UNI-T instead of Aneng? Is there a particular model with similar features to the AN 870 that you would suggest?
For example, I see that the UNI-T UT139 (C,E) have similar features to the Aneng AN870, but it has the same type of rotary switch contacts, so I do not know how it would perform better.
