Electronics => Beginners => Topic started by: J4e8a16n on April 20, 2017, 05:18:10 pm
What would happen if I wind 28 turns of .75 mm wire in the middle (200-28-200) of 400 turns of .5 mm windings? Would I have a better K factor?
Thanks for your attention.
JPD
I don't see how it would make any difference to the transformer's ability to withstand harmonic content.
Hi, Well I did it and it heats up a lot at 60 Hz....... This gapped core was a high-frequency one. Maybe that's why although I doubt it.
I tried it at 50KHz with a 555 timer. It doesn't heat.
Approximately:
I have .5 ohm and .23mH on the primary (28 turns) and
2.8 ohms and 28 mH on the secondary (330 turns).
The primary pumps 20 Watts at 4 volts. But I don't read a significant voltage on the secondary.
This seems consistent with Np/Ns= sqrt(Lp/Ls)
:o)
