Author Topic: DS1307 max readings?  (Read 1185 times)
Offline alectoTopic starter
« on: June 11, 2017, 11:40:21 am »
Well the question is in the subject... ;)
couldn't find the info in the datasheet...or the internet... :-//
currentlyI am reading the ds1307 memory every 10th of a second...wich means 36000 reads/1 hour
is it too much?
Offline ggchab
Re: DS1307 max readings?
« Reply #1 on: June 11, 2017, 03:25:50 pm »
No problem. I made a clock based on the DS1307 and I read it 10 times per second.
I could also have used the SQW/OUT signal programmed at 1Hz to read the chip once per second.
« Reply #2 on: June 11, 2017, 05:07:10 pm »
thank you  :)
belgian solidarity then... 8)
