I've lately been trying to incooperate diode mode measurements into my repair/fault-finding routine. All the cool kids on YouTube do it, so who am I to deviate.
Something I don't understand is how these measurements could possibly transfer between different DMMs. I've seen people make tables of these values and/or share them in forums etc., so that would seem rather pointless if they are only valid for the author's particular DMM.
From what I understand, the diode mode uses a constant current source to power the DUT and then measures the voltage drop. There is no standard for the current of said constant current source. I can see how that would work for an actual diode as the resistance of a diode should drop low once its forward voltage is exceeded. But in the case of repair work / troubleshooting we're measuring all kinds of points on the PCB, not just ones with diodes directly connected to ground.
Where I can't see this working is simply a resistor. If your CC source is twice as high you should observe twice the voltage drop across the resistor, right? I gave it a try with two DMMs. I know they use a different valued CC source because one of them lights up LEDs in diode mode significantly brighter. They give similar readings for diodes, but if I simply measure a resistor in diode mode they are wildly different, as I expected.
I can't see how values for many test points on a to be troubleshooted PCB could possibly be transferable between DMMs since they likely include all kinds of components in the signal path, including resistors. Additionally, since most people, for some reason, place the positive lead on ground the test points that actually have a diode in the path would all be just OL.
I don't get it.
