i have a 32khz signal, and i want to divide it without using any IC.
tha final goal is to have a fully discrete clock.
i found this:
which does exacly what i want to do, the only problem is that it works with 60hz and with +12V and -6V, while i want to make it work at 5V.
in the past few days i tried toying a bit with the circuit, but im not able to make it work.
i attached the modified circuit.
the signal that clock the circuit is a 32khz impulse, i tried with a pulse duration of 2us, 1us and about 300ns but the circuit wont change state, it remains always the same.
also, while i understand how it works, i dont understand what resistors are influencing the time costant, just R42/43 or also R40/41?
