I am restoring a little used tektronix tiny digital 222 scope. The z axis CRT drive transistors keep dying.
Not right away. It seems to take a dozen turn on/off cycles. ( I am adjusting battery charger).
The z axis data stream is 10v with 0.5us rise and fall. First failure , it half worked and I changed both mmbt5501 to restore a working display.
Again, after a few more power cycles, it's dead again. Pen down 100%.
These transistors are rated 160 v cb ce. Supply is good 120 vdc. The scope is 95% SMD, all tiny and compact but spotless being sealed.
The z axis circuit drives a 2kv rated SMD cap modulating the electron beam. There is -1600 vdc on the other side of that SMD cap, I measured it too.
Original design had no clamping diodes (bad idea Tek guys) . My early version 222 had no clamping diodes so I neatly added through hole diodes. This is still killing transistors.
Any ideas? Data sheets for tr and diodes here...
https://drive.google.com/drive/folders/1urmiwkh-uDJXATBpUcBoPrcSbcubWjtp?usp=sharing
