So something I've not been certain of for a while now. I see schematics of power supply, and single or multiple pass transistors. But whether it's a 3 terminal regulator, or something like the LM723 IC with pass transistors. The usual amount of permissible current drawn is normally around no more than 5 Amps per each series pass transistor.
The thing I don't understand, is some of these NPN or PNP transistors are rated at three or even four times that 5 Amp current in the transistor data sheet. Is there a reason why most linear power supply circuits limit the maximum transistor current to 5 Amps or so. Say you had a transistor of 30 Amps continuous current, could you not draw say 10 to 15 Amps from each of those high power transistors. I would have though half the rated current would be usable from such high power transistors. Is there something there I'm missing, because every PSU schematic I look in to always has the pass transistors at no more around 5 Amps per transistor. And a 20 Amp linear PSU might have 4 X high power transistors, which ratings might be 15 Amp or 25 Amp for each transistor. So the PSU circuit with 4 X transistors for 20 Amps maximum current, could just two high power transistors still manage the same PSU maximum current. I genuinely don't know why this can't be achieved, so long as the device is kept a good margin under its maximum rated current.
Thanks for reading, any help appreciated.
