I'm not into new old stock and am looking for a part which is avalible on mouser.
Is it true that measurements for transistors were done more precisely in the past than they are today? I was told so, but tbh that sounds really odd.
If you are going to be servicing old audio equipment, you may need to set aside your distaste for NOS. Sometimes it is the only way. In this case you can probably come up with a substitute, but if not there is an eBay seller in Spain with both transistors available, although it looks like they need a good cleaning.
For substitution, it may not be possible to find replacements that have all of the same attributes as your originals, so you need to understand your circuit so that you know which ones need to be the same and which do not. And often minor modifications are needed to make new parts work, since amplifiers tend to oscillate when you use transistor with different gains or transition frequencies.
In this case, the transistors in question were designed for use in an analog CRT television or monitor and they have a C-E voltage of 300V and a transition frequency of 70MHz--both of which I suspect are unnecessary in your audio amplifier. Can you clarify that and make sure that is true? If you do need the voltage for some reason, look at the MJE340 and MJE350 from Central, but watch the reduced E-B reverse voltage, it is 3.0 vs 5.0 for the original. Otherwise maybe the MJE180 and MJE170. Onsemi and Central are your friends.
Otherwise, let us know what type of audio equipment, what the transistor does (output transistor driver?) and what it's power supply voltages and such are. A schematic would be very helpful.
