Author Topic: transistor testing question  (Read 740 times)
Offline p.larnerTopic starter
« on: March 22, 2024, 06:34:03 am »
I have one of the chinese atmegga328 lcd based component testers,it works ok but if i try to measure darlingtons it reads wrong,for example measuring a tip-121 it gives a hfe of 48 and a tip 122 gives 50,it should read nearer 1000 beta/gain,any ideas,ie is that normal?.
Offline golden_labels
Re: transistor testing question
« Reply #1 on: March 22, 2024, 08:11:11 am »
Without knowing, what exactly the tester does: no.
But my guess would be: it’s not capable of providing voltage high enough to cross threshold of two(1) base-emitter junctions.
(1) See floobydust response below and my response. The situation is a bit more complex.
« Last Edit: March 24, 2024, 02:02:50 pm by golden_labels »
People imagine AI as T1000. What we got so far is glorified T9.
The following users thanked this post: p.larner
Offline aliarifat794
  • Country: bd
« Reply #2 on: March 23, 2024, 10:25:38 am »
The tester may not be properly calibrated for measuring high-gain transistors, leading to erroneous results.
Online Ian.M
« Reply #3 on: March 23, 2024, 11:02:35 am »
Notice anything?
Offline madires
  • A qualified hobbyist ;)
« Reply #4 on: March 23, 2024, 01:56:10 pm »
The original OSHW firmwares (k and m) would show the base-emitter resistor (the sum in this case). The modified firmware versions of the Chinese clones lack some (a lot?) of functionality in favour of a more fancy display output.
Offline floobydust
« Reply #5 on: March 23, 2024, 05:15:11 pm »
I grabbed some from the junkbox:
TIP122/TIP110/TIP102: E-B Fluke 87 reads 0.76V (forward) or 2.3V (reverse), resistance 6kΩ.
I think the last E-B junction is effectively shorted by the 70-120Ω internal resistor and cannot be seen.
GM328 reads like a normal NPN w/C-E diode, not a Darlington hFE 35-44. VBE 1.17V
Markus Frejek and Karl-Heinz Kübbeler I made reads NPN Uf 1.3V but hFE=0.
« Reply #6 on: March 24, 2024, 02:04:38 pm »
Good observation. However…
The base resistor would draw 1–10 mA, but in normal operation that is only a fraction of the output transistor’s base current. The purpose of a Darlington pair isn’t heating. ;)
With voltage only across the base-emitter junctions and small current, there isn’t enough juice for the output transistor’s BE junction to ever start conducting. This is normally supplied by the input transistor and for that all three inputs of the Darlington pair must be powered. So the diode test alone isn’t going to help much here.
I still stand by the suspicion, that the tester can’t provide enough voltage to the base.
Also note that you may be unable to see the full advertised gain on a tester. TIP121 is optimised to work in the 4–5 A collector current range. Below that the gain drops quickly. Not quickly enough to explain your readings, but you’re unlikely to see the rated 1000–2500 gain if running at 100 mA.
« Last Edit: March 24, 2024, 02:28:40 pm by golden_labels »
Online Ian.M
« Reply #7 on: March 24, 2024, 03:03:54 pm »
'328 component testers generally drive the test pins via 680 ohm and 470K resistors. That means, with a 5V supply the maximum Ic that can be provided and measured is about 7mA, with the emitter pin directly driven low. However the 470K resistor cant provide enough base drive for a power transistor in common emitter, so I suspect the test firmware configures power transistors as emitter followers for hFE measurement.  The max. Ie will be under 7mA due to Vbe drop reducing the voltage across the 680 ohm resistor, and assuming Vbe drop of around 1.2V for a Darlington, Ie will be around 5.5mA.  The ST TIP120-TIP127 datasheet fig.3 shows hFE of a bit over 60 @10mA Ic & 25°C.  10mA Ic is the left edge of the plot but if you extrapolate the straightish line downwards to 5mA the tester's low hFE results look reasonable.
« Last Edit: March 24, 2024, 08:56:55 pm by Ian.M »
Offline madires
« Reply #8 on: March 24, 2024, 03:26:49 pm »
With a current m-firmware:
TIP130: NPN, h_FE 19, freewheeling diode, R_BE 7.723 kOhms, V_BE 2.299 V
TIP135: PNP, h_FE 26, freewheeling diode, R_BE 4.789 kOhms, V_BE 904 mV
Is it sufficiently obvious that h_FE and V_BE need to be taken with a grain of salt when there's an R_BE? Or would it better to suppress the output of h_FE and V_BE in case of an R_BE?
BTW, the firmware measures h_FE in common emitter and common collector setup and keeps the higher h_FE value.
The following users thanked this post: edavid, p.larner
Offline Terry Bites
« Reply #9 on: March 24, 2024, 05:48:49 pm »
Internal Resistors in the package!
Offline floobydust
« Reply #10 on: March 24, 2024, 06:31:35 pm »
I breadboarded a TIP120 using the component tester 680Ω and 470kΩ values, off 5V. Because things can go different than speculation.
With 470kΩ to the base, of course nothing happens due to the internal E-B resistors, I got VBE=60mV and the transistor is off.
With 680Ω to the base, 5.4mA supplied VBE 1.30V and the Darlington goes saturated VCE=0.61V IC=6.5mA with RC=680Ω
I'm not sure how hFE is calculated by the testers but lack of an intermediate resistor value seems to make the tester not work in this case.
Online Ian.M
« Reply #11 on: March 24, 2024, 07:21:37 pm »
Configure it as an emitter follower with 680 ohm base and emitter resistors.  The ADC measures the voltage drop across each to calculate the ratio of base to emitter currents.  A small fudge factor should be added to the resistances in the calculation to compensate for the non-linear and level dependent GPIO output resistance.
Offline floobydust
« Reply #12 on: March 25, 2024, 03:26:44 am »
OK on the breadboard as an EF, for the science, base 680Ω to +5V, gives 0.1V drop and 4.90V on the base, for IB=0.147mA. VBE=1.17V
Emitter is 3.73V w/680Ω for IC=5.5mA giving hFE=36.3 38.3 edit: corrected hFE calc forgot IE=IC+IB for EF.
(I use 27Ω for the '328 outputs when sourcing)
« Last Edit: March 27, 2024, 08:53:39 pm by floobydust »
Online Ian.M
« Reply #13 on: March 25, 2024, 03:36:10 am »
... and now your results are 'in the ballpark', which is as good as can be expected, considering its being operated outside the range of the datasheet graphs, and the limitations of the component tester's ADC, which cant measure that 0.1V base resistor drop very accurately, as 0.1V is only 20 counts. Note the ATmega328P's ADC is specced as 0.5 LSB Integral Non-Linearity and +/- 2 LSB Absolute Accuracy, so its measured hFE could be off by a bit over 12% (2 counts + half a count uncertainty)
« Last Edit: March 25, 2024, 03:48:03 am by Ian.M »
