What you want is a scope with multiple timebases, while this was fairly common in the old analog dual channel CROs; I don’t know of any modern digital scope (up to midrange such as lecroy hdo8000 or tektronix MSO58) that has it.
Usually with modern scopes you just capture the first waveform once, store it as a reference and then trigger on the second one, that you can delay as much as needed with regular time base control
