Hello, I have recently acquired one of these:
Apart from wanting to add some additional drivers at either end which will require modifying the chassis, I am also considering changing the power source. The additional drivers may make the existing D cell placement a problem, and I am concerned about runtime with the additional power drain. The current arrangement is 8 x D cells to give 12V with a physical switch on the reverse to flick between the internal 240V PSU and batteries. There’s no charging capability. I can find on Amazon and various places what appear to be high capacity 10,000mAh cells, but I am thinking these might be rubbish. I am wondering if moving to a mobility scooter style 10Ah lithium “block” might be better but am looking for suggestions possibly including charging circuitry.
The other issue I have is this switch:
It’s a 3 position switch that enables/disables 2 amplifier circuits. In the top position, both the mono bass amp and the stereo mid/tweeter amp are enabled. In the middle position the bass amp is off (this is the issue) and in the bottom position both amps are off and the mic is on. The middle position is essentially useless and it annoys me greatly that such a switch position even exists. No one is ever going to listen to it like this. Without the bass circuit, you only get tinny music.. just take a 3 way and unplug the bass, that’s what it sounds like!
Here is a pic of the PCB:
With what I believe to be the contacts that are connected in each position. I am considering cutting the traces for the top 2 positions to repurpose this switch, but I need help figuring out if cutting these traces will kill another part of the circuit.
What I’m trying to end up with is:
Top: powering 2 x 12V TPA amp boards (1 for new drivers, 1 for original 3 drivers)
Middle: just the new TPA amp going to the original 3 drivers
Bottom: unchanged
Original 2 on board amps will
not be needed or used if this comes together as planned. I am hoping that replacing the original 2 on board amps with a newer TPA chipset will draw less power as well. I hope this makes sense. :-/
I have the service manual:
hfe_hitachi_trk-3d8_service.pdf (0 kB - downloaded 37 times.)
But not having an electronics background, I am not sure where to begin.
I would be ever so grateful for any pointers in helping change the batteries and “repurposing” this switch.
