Ultimately I want to make a current measurement across the resistor that is closest to the battery.
Then the resistor as you put it becomes a resistive shunt and to measure the current through it is by measuring the voltage across it. At DC levels this is best done with a DMM not a scope.
Ex.1) I am only using one probe.
Without the probe ground being used, I do not see any voltage on my scope.
Because there is no return path for the current.
I may add if the DUT is not ground referenced there is no chance of creating a ground loop and when this is so disregard thinking of probe ground and think of the lead as for signal reference.
This little mindshift in thinking and referring to the probe lead as a reference lead will help you understand oscilloscope measurement methodologies much better.
With all your examples you have connected the probe and oscilloscope in a way that completes a circuit and it then becomes an element of the circuit which it should not.
Hope that helps.
Its starting to help. Thank you for taking the time to respond.
I'm still left slightly perplexed. I've seen in several research papers people using two oscilloscope channels in order to make a differential measurement to determine a current. (I'm trying to acquire a current measurement of a periodic signal on the order of 1MHz)
I attached new examples in my reply to you.
In example 4, my scope channel acquires a signal across the resistor of 9.6 volts
Making a differential measurement in example 5, I again acquire 9.6 volts
Both examples yield the same measured current voltage.
See small correction above.
Yes, you have two differential voltage measurements of the battery voltage only.
Now add another 1M \$\Omega\$resistor in series and do a differential measurement across that. Why 2 ? One represents the circuit load and the other represents the current shunt that will have a voltage drop across it that represents the current value.
These are unfortunate values that coincide with the probe resistance but in a real measurement the shunt resistance will be much lower, max of an Ohm or two.
Going back to my original post and examples, it appears there should be some corrective factor that I can determine through circuit analysis theory in order to make the current measurement I am attempting to make in example 2 shown in the original post.
There is NO corrective factor as the probes and connection methodology has an influence on the measurement value.
I add this statement again for your OP examples:
Keep in mind ANY measurement in some way alters the measurement value itself.
