Author Topic: trigger option?  (Read 565 times)
Online Adrian_Arg.
  • Country: ar
trigger option?
« on: April 10, 2018, 02:21:13 pm »
Hello, I have a Rigol DS1054Z, the question is, which trigger option to use in SINGLE mode, which is triggered, when the voltage exceeds a certain value?
Offline TK
Re: trigger option?
« Reply #1 on: April 10, 2018, 03:06:53 pm »
Use edge trigger and set the trigger level to detect when voltage goes above the threshold.
Online Adrian_Arg.
  • Country: ar
Re: trigger option?
« Reply #2 on: April 10, 2018, 04:37:18 pm »
sorry, that's the best choice the rigol has for simple voltage shot? :(
Offline ebastler
Re: trigger option?
« Reply #3 on: April 10, 2018, 07:00:19 pm »
What is wrong with that "choice"? I.e. what would you like to achieve, and can't quite get done with Single Edge triggering?
Online Adrian_Arg.
  • Country: ar
Re: trigger option?
« Reply #4 on: April 10, 2018, 08:56:56 pm »
I would like it to fire not on the edge, but at a voltage deterninado, that if I am working with 7volt and deciente at 6 volt will be triggered.
Offline TK
Re: trigger option?
« Reply #5 on: April 10, 2018, 09:00:29 pm »
That is what edge trigger is for.  Set it descending, then threshold just above 6V, and the scope will trigger when voltage descends to around 6 V from a higher voltage
