It should work. The problem may be that it is powering-up in the triggered state.
Also, the values used for the trigger pulse are likely too large. If you don't have an oscilloscope then you should grab a simulator so that you can get a better idea about what the circuit is doing and how the component values effect the circuit's behavior.
