Trimpot is used to supply 0-10V at wiper. Its resistance is quite low at end positions and does not really matter.
If you look at internal schematic of REF102 in the datasheet, you will find internal resistor values.
Trim range with 3.6M resistor should be around +/-29mV. You can approximate it with 5*(1-(x+50K)/(x+72K)), where x is 3.6M resistor.
