Author Topic: Trivial capacitor based battery tab welding machine  (Read 5296 times)
pereczes
  • Guest
« on: April 23, 2014, 11:48:08 pm »
another research I was doing was about welding tabs to a li-ion battery. Soldering seems to be difficult due to dangers of over-heating. Remember when I was kid was discharging capacitors, low charge ones and two metal thingies were sticking together from the spark energy.
Wonder if that would be possible with a high 100F capacitor to stick a nickel tab to the battery.
Found another thread here and tons of videos with over-engineered devices and tools.
for me the idea is to load the capacitor and the booom (hopefully not my head ;) )
Offline calexanian
    • Alex-Tronix
Re: Trivial capacitor based battery tab welding machine
« Reply #1 on: April 24, 2014, 01:53:15 am »
Typically capacitor discharge welders for battery tabs use a step down transformer to generate high current and switch on the high voltage side. It's very common. Just you tube videos of battery tab welders. I built my own out of a big variac and a harbor freight spot welder with a foot pedal to close the jaws and some bending of some micro welder electrode rods.
Charles Alexanian
Alex-Tronix Control Systems
Offline Rerouter
« Reply #2 on: April 24, 2014, 02:12:28 am »
Most of them rely on voltage rather than capacitance to make the massive currents necessary, on i worked on a few months back had a voltage control know and a trigger button on a lead, it charged up the capacitor bank with a SCR rectifier, so that it would stop charging once past set point, then when you hit the trigger circuit, some active device would shunt the capacitor array across the 2 leads
Offline GeoffS
« Reply #3 on: April 24, 2014, 02:18:29 am »
A couple of DIY designs for capacitive discharge welders
https://ultrakeet.com.au/write-ups/cdWelder
http://frikkieg.blogspot.com.au/
Offline Rerouter
« Reply #4 on: April 24, 2014, 10:04:27 am »
I would strongly recommend even a crude trigger circuit, so you can get things in place, nice and firm and then hit to weld, i would not want dangerous voltages constantly on the wires, and tapping to zap will burn the surface more than weld,
Offline SArepairman
  • wannabee bit hunter
« Reply #5 on: April 24, 2014, 07:21:14 pm »
Ah you guys gave me the idea to modify my home made optional isolation variac box to be modified with a switch that disconnects mains and connects the mains input through additional connectors on the front panel so I can hook up a capacitor and use it as a spot welder. good idea?
what voltage/capacity capacitor did you use for yoour variac spot welder?
could I use a 10000uF capacitor charged to 170V discharged through a variac?
how good of a pulse circuit do you need? I'd prefer a low tech momentary contact switch solution.
« Last Edit: April 24, 2014, 07:53:36 pm by SArepairman »
Offline ion
« Reply #6 on: April 24, 2014, 09:57:09 pm »
Well, you can't get much simpler than this: http://ledhacks.com/power/battery_tab_welder.htm
Just make sure to somehow disconnect the power supply before you trigger the SCR.  IIRC there's a note somewhere on that site that  leaving it connected eventually caused the power supply to fail.
Offline calexanian
    • Alex-Tronix
« Reply #7 on: May 15, 2014, 05:30:26 am »
The more I use my home made AC welder the more I like it. I use a 10 amp variac with it, typically at about 60 to 70 volts for nickel strip of the sort used for battery ribbon and its happy. I have it rigged up to a foot pedal that closes the jaws and hits a switch and applies power. Very handy for all sorts of things. I use it primarily for my vacuum tube hobby stuff but i find myself using it for all manner of other things around the shop.
Charles Alexanian
