Checking with the Siglent scope experts: I'm new to DSOs, have recently acquired an SDS1104x-e, and I'm trying to capture the serial output going to my Picaxe board (i.e. the programming port) as an exercise to learn how to use the serial decode functionality.
However, despite following the manual very closely, I cannot figure out how to get the scope to even trigger on the "serial" trigger setting with the UART protocol selected, let alone decoding it. If I set the trigger to "serial" and the protocol to I2C, it triggers on my serial signal just fine. But if I set the protocol back to "uart", the scope simply ignores my serial input.
I've set the "9600, 8, N, and 1" parameters, set the Trig Bus for "idle level low" (that seems to be what's coming out of the comm port -> USB adapter), and re-checked every other setting (and have futzed around with them all as well in desperation).
I can't find any info in the manual about the actual serial/uart triggering criteria, i.e. what parameters are crucial, etc., and thought I'd ask here if anyone has gone through similar frustration and has discovered the hard way some absolutely critical parameter in the serial/uart trigger setup that I've overlooked. I've also checked that the baud rate shown on my terminal software (termite), matches the baud rate of Windows Device Manager comm port driver (i.e. the Picaxe USB/serial cable driver), and lines up with the baud rate that set for the UART trigger.
Any suggestions? Once I get it to trigger properly, then I can move on to actually trying to get the scope to decode...
Thanks for any help!
