Hello
I have a problem with importing an IC from PSPICE file to the LTSPICE software.
The part is AMC3330. The steps I did:
1) Copied the downloaded AMC3330.lib (extension of the file does not matter) to my Documents\LTspiceXVII\lib\sub
2) Started LTSpice and opened that file
3) Highlighted the component name besides “.SUBCKT”, then right-click and selected “Create Symbol”.
4) Saved that file and got it in AutoGenerated folder (Documents\LTspiceXVII\lib\sym\AutoGenerated)
Unfortunately, when I insert this exact symbol into the diagram, after clicking Run in LTSpice, the RAW window with waveforms/charts stops opening.
There is probably something wrong in this converted file that I am not seeing that is causing the error in this element. So far there has been no problem with other components converted from PSPICE to LTSpice in the same way, but the AMC3330 is a bit more complex.
This PSPICE file comes from exactly here:
https://www.ti.com/product/AMC3330#design-development##design-tools-simulationI attached the file I converted to the post.
Is it possible that this type of file is simply not convertible to LTSpice? If so, how to recognize such files? I don't have PSPICE software to verify components.
