Electronics => Beginners => Topic started by: Bastel1991 on December 24, 2016, 10:29:49 pm
Hey @all,
Im trying to troubleshoot the amplifier that's named in the title, the main fault is that it's literally destroying everything you hook up to it on the front channel, I checked with my multimeter the output and I get almost 21 volts without any signal that it could be amplified.
My first thought was that one of the 4 power transistors is gone bad, but I'm not really sure how to test them I tried various methods with the multimeter on diode test but if I done it right and my readings are correct 3 out of 4 power transistors are gone bad and somehow I can't believe this.
Can anyone give me a hint in the right direction?
Thanks for you time :)
(http://uploads.tapatalk-cdn.com/20161224/a4ad7936395c208cc4c70d8d13024710.jpg)
(http://uploads.tapatalk-cdn.com/20161224/7742038ad68b53d310731e688e88e64f.jpg)
(http://uploads.tapatalk-cdn.com/20161224/d347383f1941fae221ec93388d984969.jpg)
why do you think this can't be? It is a fairly common fault that the power transistors blow up, so no problem with that.
But how did you test those?
