Hello all,
I am trying to troubleshoot the laser scanner assembly on my laser jet. The fault codes indicate a problem with the laser assembly (more specifically the Yellow diode - Code 51.23). I wanted to try to probe the diodes and see if they work.
How would I do this? Can I simply probe with my multi-meter on diode check? What output should I expect? I mean, I take it it is invisible light. Should it "burn" a piece of paper? I have no specs on the diodes in use.
Also, what probe points should I use? I take it LD is Laser Diode, COM is GND but what about PD?
I've attached a picture of the board.
Thanks in advance,
