I've been looking to understand the pass transistor. The video above is disrupting my understanding transistors. In this circuit which the video reproduces the circuit below, it's putting out a voltage of 12.5v, but allowing current up to 4amps with a LM317 voltage regulator (max of 1.5amps) (well, unless he is feeding it a regulated 12.5, but that wouldn't fly in the face if the intent here wouldn't it)
What I'm not understanding is how the LM317 is managing to keep the voltage at 12.5v after you turn on the transistor. When the transistor turns on, wouldn't that allow not just more current to flow, but also whatever the voltage is behind it through too?
Or is the LM317 some how throttling the MJE2955 so that it only allows current while the LM317 provides all the voltage?
