Author Topic: Trying to derive equation out of lm317 datasheet  (Read 1931 times)
Offline avogadroTopic starter
  • Country: hr
« on: October 31, 2018, 04:52:12 pm »
I was just trying to derive the equation for output voltage of lm317 for fun and I cant get it. Dont know what Im doing wrong. I attached the image of what I was trying to derive. The closest I get is V0 = Vref((R2 + R3)/(R1)) - 10.
Offline spec
  • MALE
Re: Trying to derive equation out of lm317 datasheet
« Reply #1 on: October 31, 2018, 08:07:39 pm »
+ avogadro
Revised schematic with formula for output voltage attached.
Offline westfw
« Reply #2 on: November 03, 2018, 06:56:26 am »
In your second picture: R3, D1 (a zener) and C2 essentially form a conventional -1.25 zener voltage regulator, with the -1.25V output at the D1/R3 junction.
R1/R2 and the LM317 are the normal lm317 regulator, with the "adjust" input biased to -1.25V instead of ground. offsetting the normal 1.25V regulation point of the 317.  (which tries to make sure that Vout is "Adjust+1.25V")
Offline spec
  • MALE
« Reply #3 on: November 03, 2018, 11:02:38 am »
Yeah, that is right. Just standard stuff, straight from the datasheet. :)
