Electronics => Beginners => Topic started by: netham45 on April 04, 2021, 02:22:40 am
Title: Trying to find a denser LED than the 100w COBs on Amazon
Post by: netham45 on April 04, 2021, 02:22:40 am
I have some 100W LEDs I got off of Amazon that I'm shining through a small 2mm^2-ish hole onto a projector. I'm looking for something that has the LEDs more dense on the board so I can get more light through that hole.
If I could find something like a normal 100W LED COB that had all of the LEDs in a smaller area that would work, or if I could find a chip with the same density but brighter per LED that'd also work.
I found http://fcopto.com/portfolio-items/luna-200/?portfolioCats=3 (http://fcopto.com/portfolio-items/luna-200/?portfolioCats=3) which looks like it would do what I want but I can't find it for sale anywhere. Does anyone know where I can find an LED like that or a comparable one?
Title: Re: Trying to find a denser LED than the 100w COBs on Amazon
Post by: mvs on April 04, 2021, 08:07:33 am
The hole is way to small for a COB LED, look for Cree XHP or something similar.
Post by: Marco on April 04, 2021, 09:46:32 am
Car LED headlights?
Post by: mikerj on April 04, 2021, 10:28:42 am
Could you not put a condenser lens between your LED and the hole?  You'll be throwing away a huge amount of light otherwise.
Post by: beanflying on April 04, 2021, 10:46:43 am
Sounds much more like you need an optical solution as much as more power. What are you projecting into/onto or through? Would you be better to look at something in the visible Laser area for a solution?
