Author Topic: Trying to simulate the function of a TVS diode in LTspice  (Read 364 times)
Offline fubar.grTopic starter
  • Country: gr
    • Fubar.gr
« on: March 29, 2025, 10:40:58 pm »
I made the attached circuit in LTspice.
It is a 12 Volt AC source with 50 Volt spikes feeding a 90 Ohm resistor. So I added a SMBJ24CA TVS diode in parallel, expecting it to clamp the voltage to something near 24 Volts.
But it doesn't work. The voltage spikes pass unobstructed to the load.
Am I missing something or is this how the TVS diode is supposed to work?
Offline tggzzz
Re: Trying to simulate the function of a TVS diode in LTspice
« Reply #1 on: March 29, 2025, 11:13:51 pm »
They are ideal voltage sources that can supply infinite current.
Look at the current through the TVS, and insert a resistor between the TV'S and the voltage sources. Resistor value is chosen to set the desired maximum current.
