Hey,
My girlfriend got this question which I don't understand.
The question is:
"What is the absolute value of the transfer function of Input Current / Input Voltage, write your answer in mA"
How do I write a ratio in mA?
Is the problem solvable?
Thanks.
Maybe he really wanted you to write the answer in units of bananas per second
If this is a real question then it can be interpreted in different ways, really. You'd have to find out which way, and may have to go over his head.
For example, if we are to take the voltage to be a constant, then the answer can be written in amps or milliamps. Not sure why he would want to do that though.
He also maybe meant to write the answer in milliunits but had amperes stuck in his head too so wrote 'ma' instead.
Also suspect is the phrase "absolute value".
I don't think the absolute value has any real use for this application, what he probably meant was to find the magnitude, which is often written the same but has a different calculation:
magnitude of x=|x|
but since here 'x' is a vector (interpreted as just an AC quantity) it's not the same as abs(x) it's really sqrt(r^2+i^2) with 'r' the real part and 'i' the imaginary part, also called the 'norm'.
