Author Topic: TVS diode  (Read 1793 times)
Offline Vcky_electroTopic starter
  • Country: in
TVS diode
« on: May 21, 2019, 03:29:19 pm »
Im using two Type-C connector in my board. ONe is for data + power and another one is for only power. Do i use TVS diode for both connector ?  or one TVS diode is enough for both connector.
(Note: Both connector power is Vbus=5V)
Please let me know if anyone knew..
Thanks,
Vicky.
Offline piguy101
Re: TVS diode
« Reply #1 on: May 23, 2019, 01:21:21 am »
Not exactly sure what you are talking about, but it is often good practice to include a TVS diode on every single signal wire (and power wire) coming into a device when transients are possible. You never know which pin could have a nasty spike on it for some reason.
Offline Lt_Flash
Re: TVS diode
« Reply #2 on: May 24, 2019, 06:17:00 am »
Thanks,
Vicky.
You put one TVS diode per each line. Usually there are TVS diodes in a pack for USB - they have 2 TVS diodes and 1 Zener diode, for example - prtr5v0u2x. This one has a Zener diode to clamp voltage and two TVS diodes for anti-static protection. If you're using something like uni-directional TVS diode Vishay SMP13A-M3/84A - you put each of them on protected line. If you're using multiple connectors - you put one TVS pack for each connector, see example here:
https://static5.arrow.com/pdfs/2014/6/5/0/43/53/634/mcp_/manual/328evb-usb2514b-fs_a12020evaluation20board20schematic20pdf.pdf
