Author Topic: Worcester Bosch boiler PCB - identify 64pin TQFP IC  (Read 323 times)
Offline armandine2Topic starter
« on: August 10, 2024, 12:33:24 pm »
https://www.trustapart.co.uk/product/worcester-87483004840-printed-circuit-board/
I have a fly tipped PCB which looks to me like the one in the link.
It has a 64 pin TQFP IC with code below - not found online
F0138
1401EP201
M2
JAPAN
I guess this could be management system controller?
[edited to add a pcb picture - after all components removed]
« Last Edit: August 11, 2024, 11:20:51 am by armandine2 »
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline squadchannel
  • Country: jp
  • deepl translate user
Re: Worcester Bosch boiler PCB - identify 64pin TQFP IC
« Reply #1 on: August 10, 2024, 12:40:13 pm »
have an image of the IC? :o
« Reply #2 on: August 10, 2024, 01:05:14 pm »
thanks - I found that too
  • Country: jp
« Reply #3 on: August 10, 2024, 01:06:57 pm »
Judging from the "JAPAN" font, I think it is a NEC microcontroller.
It maybe uPD78F0138.
Compare from the position of the power supply pins, etc. If they are in the same position, they probably are.
Since it is a MaskROM, I don't think you can dump the firmware. It may be better to give up.
I compared it to other NEC microcontrollers, but it has the distinctive #1 pin identification marking. I am sure it is correct.
2335783-0
« Last Edit: August 10, 2024, 01:15:38 pm by squadchannel »
The following users thanked this post: armandine2
« Reply #4 on: August 10, 2024, 01:56:15 pm »
good point about the mask rom
just watched Shahriar getting stuck into that process
