Author Topic: I need help identifying component(3729B AKAF)  (Read 361 times)
Offline cold_zeroTopic starter
« on: August 08, 2024, 04:25:27 pm »
i need help go get datasheet for ic 3729B AKAF i found it on motherboard gopro5
it's marked by rectangle
thank you
« Last Edit: August 09, 2024, 06:54:24 am by cold_zero »
Offline golden_labels
Re: I need help identifying component(3729B AKAF)
« Reply #1 on: August 08, 2024, 04:39:09 pm »
Without a good quality photos of (1) the chip, (2) the chip and its neighbourhood, nobody can tell much. May be anything.
For example the first result while searching for phrase ‘3729B AKFA’: AMS AS3729B “8A Power Stage”. The markings described in Fig. 15 (p. 12) of the datasheet are matching your description.
« Last Edit: August 08, 2024, 04:41:26 pm by golden_labels »
People imagine AI as T1000. What we got so far is glorified T9.
« Reply #2 on: August 09, 2024, 06:55:50 am »
you are right , sorry it's my bad i edit the post and add images
« Reply #3 on: August 10, 2024, 05:33:39 pm »
The lime square marking hides all the traces, but it seems to be roughly matching (Fig. 3 on p. 3, rotated by 180°). The presence of inductors and fat traces also suggests this is a power supply chip.
