I took apart the switch in a cheap broken cordless drill I had... this one wasn't potted in epoxy surprisingly. reverse engineered the circuit... and drew a shematic...
I could've gotten the NE555 pins wrong by 180degrees... idk, it had no notches on it and I'm not too familiar with IC's, or SMD stuff for that matter...
the SOT package too... it had 'A73' writen on it, so I asumed it was some 2SA73- BJT, and for that too I could've gotten the wrong BJT with a diffrent pinout, since it makes no sense how there's like no grid leak, no collector supply, no emitter drain... it just seems like it it wrong af....
I don't know where the pins connected to the mosfet and the big diode since it fell apart when I got it open.
if it helps the diode was a 6A4, and the fet was a 50N06
