Is there a formula for this anywhere? What I mean by the subject line is when you add 2 waves of the same frequency and amplitude together, but vary the phase. Obviously when in phase the resultant output is doubled, and when 180deg out of phase there is no resultant at all. I can see using circle vectors that at 120 deg phase shift, then the combined output is the same amplitude as each of the two input waves.
Feeling stupid I can't find the formula online!
