My parametric search abilities are failing me here, and digikey does not allow me to do a raw SQL query
I need a small pushbutton switch with two circuits, both normally open. When I push the button halfway, the first circuit is closed, and when I push it all the way both circuits are closed. Does such a beast even exist?
(Of course I know I can have two pushbuttons one next to the other, press one, then press the other. Or do it with a 556 to have a delayed monostable pulse, and it will probably be cheaper than the pushbutton switch, but still...)
The use case is having a one-finger operation for putting the ESP8266 and its ilk to upload mode: you pull GPIO0 low, pull RESET low, release RESET, release GPIO0. It *has* to be done in that order, can't even do it simultaneously (as if simultaneity existed in circuits, but that's for another show
Cheers,
/ji
