Author Topic: UART Communication between GSM and GPS  (Read 585 times)
Offline AankurTopic starter
  • Country: in
« on: April 24, 2019, 10:01:02 am »
I want to establish a UART Communication between GSM and GPS.
The Supply Voltage of GPS is 3.3V.
The Supply Voltage of GSM is 3.8V.
The measured RX/TX Voltage Levels of GPS is 2.8V and 0V (for logic High and logic Low).
The measured RX/TX Voltage Levels of GSM is 1.8V and 0V (for logic High and logic Low).
Since there is a difference between RX/TX logic levels of the GSM and GPS, So I am
not able to establish the UART Communication between GSM and GPS.
I am using the interpreter of the telit GSM module to process the data of the GPS.
I am not using any micro-controller to in between the GSM and GPS.
Please suggest me a possible way to perform voltage (or Logic) level shifting.
Offline MadScientist
Re: UART Communication between GSM and GPS
« Reply #1 on: April 24, 2019, 11:13:15 pm »
A simple transistor circuit on the relevant Tx lines will do the job
EE's: We use silicon to make things  smaller!
