So I am having a little trouble understanding the physical layer of the LIN transceiver.
I've attached a crudely painted sketch of the transciever and signals I am interested in and what I think will happen. So, from my understanding, the LIN transceiver just does a buffer delay and signal filtering. From that, in the event that one uC sends out a serial message on TX, it will receive its own message on its RX at a delay; then, the protocol of the sending uC unit must understand that the RX signal it just received must be ignored, correct?
So, just to clarify fully, I cannot attach a LIN transciever to two connected uC's and use the standard Serial.send and SerialEvent() methods of a typical arduino serial library/protocol because of the resulting send and receive collisions, right?
