Im a very fresh newbie, Been watching EEVBlog for a while but just got my first muiltmeter
I would love some tips and tricks but i have some questions in relations to measuring stuff for my Logitech racing wheel that im remaking a cable that would of come with it when it was new.
When measuring voltage on a connector, for example something like a USB plug (which i know the pinout off the top of my head), how do you measure voltage?
I would guess that you touch 1 Pin with the red probe and COM would go to ground.
This cable would go from RJ232 to USB and i want to double check pinouts and voltages so i dont fry anything.
So far pin 5 is Ground which is correct to the pinout im using to recreate this cable but for the rest of the pins im so fresh i dont quite how to figure them out, like confirming Data + and Data - as well as the power line.
Chris
