Author Topic: Small beginner reflow oven for Australia  (Read 2045 times)
Offline rthorntnTopic starter
« on: June 26, 2017, 07:21:10 am »
Hi All,
I want to pickup something for a beginner to do a low volume (hobby) small boards safely and with good results, budget is $1000 AUD so something better than the cheap chinese aliexpress stuff, it needs to be $1000 including shipping/duties/taxes to Australia, is there anything?
I would rather it comes ready to go.
Thanks.
Richard
Offline David_AVD
Re: Small beginner reflow oven for Australia
« Reply #1 on: June 26, 2017, 09:03:39 am »
If you're using leaded paste the Breville BOV800 toaster oven works well.  Been using it for a couple of years.  There may be a newer model these days of course.
The following users thanked this post: rthorntn
« Reply #2 on: June 26, 2017, 09:25:09 am »
Lead free solder paste would be much better.
Is there a gap in the market here between $300 Chinese ovens and $2000+ pro ones?
« Last Edit: June 26, 2017, 09:54:16 am by rthorntn »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #3 on: June 26, 2017, 09:33:00 am »
Is there a gap in the market here between crappy $300 Chinese ovens and $2000+ pro ones?
I used to use a $300 reflow oven to manufacture PCBA for our Japanese customer when I worked in my hometown in China.  ;D
« Reply #4 on: June 26, 2017, 11:37:40 am »
I read somewhere on EEVblog that the cheap Chinese machines needed a more height, better heat distribution and a better control system...
Nothing half decent for $1000 then?
Offline David_AVD
« Reply #5 on: June 26, 2017, 11:47:03 am »
So this is for hobby use but you want lead-free ?
« Reply #6 on: June 26, 2017, 12:21:35 pm »
The lead free requirement came from the environmental impact of lead.
Offline rstofer
« Reply #7 on: June 26, 2017, 01:48:29 pm »
I use a Black & Decker Infra-Wave Toaster Oven but I believe it is out of production.  It has 4 lamps, 2 on top and two on the bottom.
To get the heat cycle to work, I had to add high temperature insulation between the inner and outer walls.  I bought this as a sheet and just cut it to fit.
For control, I used an Arduino Reflow Oven Shield as the control system.  I'm not sure how it works with lead-free solder as I am using leaded.  There is nothing in the law (in the US) that says I have to use lead-free solder for personal projects.
http://www.rocketscream.com/shop/reflow-oven-controller-shield-arduino-compatible
