Hi there, first timer here. I’ve taken on a job of repairing a wine cooler, and have confirmed the PCB to be the problem. Power comes in, most components are getting power, but the final relay before the output to the compressor is not closing. With the relay not closing my first thought was it was faulty but I removed the relay and it tests fine on a 12V battery.
Any other suggestions? Any parts on here that stand out as worth checking?
Thanks!
