Hello all,
I want to use a ZLED7020 chip to drive an LED. However, rather than providing a PWM signal to choose between 50% and 100% duty cycle (approximately), for 50% brightness and FULL brightness, I want to under-drive the LED (by lowering the current). I want the light to have 2 power modes, 1/2 brightness and full brightness.
Using the ZLED7020 chip, there is a Set resistor which chooses the constant current the chip provides. Thus, with a 3 position knob / switch, I can have it choose between 2 resistor values and "off" if you will.
What are the potential problems of under-driving the LED? I want to state that I am aware that the proper way to drive the brightness of LEDs is with PWM, but I wonder if in my case I'm within the LEDs parameters?
I want Brightness 1 to be around 600mA and Brightness 2 to be around 1Amp. I have attached the LED FW Current / FW Voltage chart.
