When using a BJT (NPN) as a switch, there is no classical hFE, but you still have to assume a reasonable Ic/Ib ratio to put a transistor into saturation, while keeping the Ib current as low as possible (to not waste energy/create needless heat), and choosing the biasing transistor accordingly.
Reading
https://www.reddit.com/r/AskElectronics/comments/7z3cvn/what_is_the_difference_between_beta_and_forced/ (https://www.reddit.com/r/AskElectronics/comments/7z3cvn/what_is_the_difference_between_beta_and_forced/) and
https://electronics.stackexchange.com/questions/207374/forced-beta-too-small (https://electronics.stackexchange.com/questions/207374/forced-beta-too-small) or this
https://www.physicsforums.com/threads/transistor-current-gain-in-saturation-mode.865392/ (https://www.physicsforums.com/threads/transistor-current-gain-in-saturation-mode.865392/)
it seems 10 is a common value for forced hFE.
A video showing the base resistor calculation for saturation mode: https://www.youtube.com/watch?v=hEVLJc4R9JE
When looking at this datasheet (https://www.mouser.com/datasheet/2/149/BC547-190204.pdf) for example, in Figure 4 Ic/Ib = 10. But when looking at the table on page 2, the values for VCE(sat) suggest a ratio Ic/Ib = 20.
This raises a few questions:
- If there is no constant Ic/Ib ratio (table vs. figure), how can you make a measurement at Ic/Ib=10, as in Figure 4?
- People speak of setting the Ic/Ib ratio to a forced beta, how exactly is this done? (The figure shows a varying range of Vbe and Vce, so it can't be those voltages controlling Ic/Ib.)
In other words, I am confused how the forced beta values were obtained. "Normal" hFE could be measured for a transistor in the active/linear region.
