Author Topic: Stubby fingers vs Ben  (Read 760 times)
Offline PerranOakTopic starter
« on: February 23, 2022, 07:54:56 pm »
So, I am building the Ben Eater 6502 breadboard machine for fun.
The problem I have is with my stubby fingers: I simply cannot get all the leads into the breadboard without squashing it all.
What it need is something I can put the cpu into and then feed wires out to the breadboards to give more room.
Every time I Google “break out board”, etc. I can ads for bl00dy rpi and so on.
Is there any generic thing I can get (40 pin) that will do the job?
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline jpanhalt
Re: Stubby fingers vs Ben
« Reply #1 on: February 23, 2022, 07:59:11 pm »
Serrated tooth tweezers about 6" long.  Some people call them "pick-ups."  That's what I use.  My fingers aren't particularly stubby, but in the Winter, they are cracked, bleeding, and painful.  If you can get non-magnetic ones, you will be happy, but regular also work.
The following users thanked this post: Ed.Kloonk
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #2 on: February 24, 2022, 02:47:02 pm »
Cheers.
Is this any use to you?
https://www.ebay.com/itm/40-Pins-ZIF-Socket-to-DIP-Screw-terminals-Breakout-Board-Module-/302297245415
iratus parum formica
The following users thanked this post: PerranOak
« Reply #3 on: February 24, 2022, 05:02:04 pm »
That is perfect mate, cheers!
RJD
